sunroof: grease, oil or silicone?
jasonsos
Car: 1993 Invinity J30t
* Special thanks to Gerardjg for above and beyond help!When I first bought my J30t almost 2 weeks ago, the sunroof wouldn't pull back all the way, so i sprayed some silicone on the tracks, cleaned the gunk out, and then sprayed them again.I have since been told by a body shop guy that I should only use 'grease.'My thinking is body guys do body work; you guys do the repairs. Which should I use?I guess that from some of the other posts I have seen and read, I am lucky that the tilt up and the sunroof still actually work on this 93 J30t.BYT: what does the 't' stand for?Thanks to all.BTW2: still haven't found a fuse for the ASCD, only the rely under the hood called the ASCD HOLD relay. Referring to the manual, I see that it could be a number of things: speed control switch, speed cable, brake pedal switch, pump, actuator motor, the buttons on the wheel. The dash light does come on when pushed, the control cable seems okay as does the pulleys and vacum lines, so it looks like a dealer repair. Thanks to all who made suggestions.B-kool.Jasonsos
captainluigi
Car: 1996 q45t
a product called silglide has served me well on numerous roofs over the yrs. also good for latches and the like. i have a Qt. there the t stands for touring. in my case thats dif. wheels and a lrgr . diam. rear sway bar plus different steering geometry. search here or just google that model.
Skibane
Car: 2000 Q45 AE 110K
On the Y33, the Sunroof section of the service manual only mentions putting "petroleum jelly" on the rail groove and wire. I couldn't find any other mention of a recommended lubricant.
The Sil-Glyde suggestion sounds promising - It has about the same thickness as Vasoline, is silicone-based, and harmless to rubber. Auto Zone sells small "ketsup packets" of it for about a buck; you can also buy a 4 ounce "toothpaste tube" at NAPA for about 6 bucks.
jasonsos
Thanks. I'll try that.I think you're correct in the case of a J30t: 'touring package.' Better suspension.Jasonsos
jasonsos
Thanks for your post. I got a huge bottle of petrolium jelly let over from something that happenmed.Jasonsos
captainluigi
Car: 1996 q45t
you may want to do a little more research before applying petroleum jelly. the key word being ''petroleum''. do not think it is compatible with rubber. also it seems to turn to a messy goo over a period of time. least that was my experience.
qship96
Car: 1996 Infiniti Q45
white lithium grease,applied sparingly to tracks gets my vote
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:white lithium grease,applied sparingly to tracks gets my vote
Along with Wurth rubber preservative.
Make sure the tracks are clean.
Skibane
maxnix wrote:
Quote »white lithium grease,applied sparingly to tracks gets my vote
Make sure the tracks are clean.[/quote]Most lithium grease also contains the dreaded "petroleum"...
If PJ is good enough for the FSM, it's good enough for me...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AS long as it is confined to the rails, it is fine. I think the lithium has more staying power, though.
captainluigi
Car: 1996 q45t
lithium is good and it can also keep you stable. as with all meds, proper dosage is paramount.
