Sunroof Drain tubes
Hoffman5982
Car: '95 sr20det 240sx
I was wondering if anyone could enlighten me as to where the sunroof drainage tubes go. I'm talking about the front drivers side. I have a clog somewhere down by the fuse panel. I know this because I shot some water down and it is just sitting in the tube down there. I figured I'd go from the the bottom of the tube and stick a pipe cleaner in to unclog it
Shabbernigdo
if there in the same locations as the s13 tubes they are routed through the metal behind the plastic rear seat pannels.
Hoffman5982
the s14 has 4, and the front 2 go down the A pillar. Im guessing the s13 only has 2?
Hooked on 240
Hoffman5982 wrote:the s14 has 4, and the front 2 go down the A pillar. Im guessing the s13 only has 2?
All 240s no matter if its coupe/hatch/vert s13/14 ALL have 4 tubes and ALL go to and from the same places.
not sure where yours go on the s14 but on my s13 they go from the sunroof down to the a pillar then stright down to the front fender.
Hoffman5982
alright thanks, I looked and didn't see any holes on the bottom of the car where it would come out
C3Sierra_S2000
Car: 1997 240SX SE LS swapped
The easiest way to clean out your drain tubes is with compressed air. Just use an air compressor and it will blow all the crap out the bottom.
