Thanks Any help is appreciated
Fonzie
Sounds like they're clogged and just overflowing the pan, generally water from that will come down inside the A-pillars. If you don't have compressed air, try snaking some edge-trimmer line down the tubes to clean them out. It's remotely possible that both hoses are off the nipples beneath the headliner, but very unlikely. One side yes, but not both. Chances are they're simply clogged.Fonzie R51 wrote: ↑Mon May 03, 2021 10:19 amHi folks ever since I got my beloved 08 R51 water has pored down both front pillars and I heard it was probably the sunroof drain tubes so I poured a small amount of water down both and it is as if they are not even connected. There is a small amount that comes out via the format wheels but most comes out inside the a pillers and soaks everything. I do have a car port so have put off investigating until now. Just wondering if any of yous have dropped the roof lining before as there seems to be airbags everywhere and have yous ever heard of the fronts becoming detached or broken before?
Fonzie
