Sunroof Drain Pinch/Kinked on Passenger's Side
General discussion area for the L32-chassis Altima
npolite
Hi All,
I've found the cause of my water leak at the passenger's side floor. The drain hose for the sunroof was not flowing and it seems to be a pinch in the hose. I guess this is because of not using enough hose to avoid the pinch or cheap materials. Anyway should I just get a extender adapter and then add some tubing to where it enters the drain hole to the outside or would a 90 degree elbow be better? Anyone know the size off hand? I think it might be 3/8" ID.
https://photos.app.goo.gl/7Df87eoKPbTHuEM39
https://photos.app.goo.gl/YfPPbKCih1eHQ6kJ6
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Get a lightweight spring that fits over the tube to keep it from collapsing again. Tube menders are a bad idea, the leading edge just creates an invitation to a clog.
npolite
Thanks for the reply. Do you have a link to one that I could use? Do you think a hose camp just enough pressure will work or do you think it will fall off?
npolite
Ok I remembered I have these but of course I would have to ransack the basement for them :)
I'll order a set from Amazon.
https://www.amazon.com/Compression-Asso ... ing&sr=8-7
VStar650CL
Technical Expert
There you go. That's the sort of kit we have at the shop.
Return to “4th Generation Altima Sedan (2007-2012)”
