95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Dec 10, 2006 6:29 pm
had that problem not too long ago, check the contacts on the switches.....
take the sunroof control/map lights unit out...... unplug the wires (3 sets i believe), the switches boards will be visible, carefully and very slowly bend out the 4 metal lips holding the board to the switch assy. , clean the contacts with a clean cloth (i used a very fine sand-paper as well to insure proper functioning), clean the contact side too..... put everything back.
that did the trick for me, and i never had a problem with them since.....
hope this helps, good luck
