sunroof breaker
Boomstickdave
Car: 1994 infinity j30
im having problems with my j30 sunroof n just want to disable it. i never use it so have no point to keep having it go crazy. just the map on the back of the relay box isnt very helpful so if anyone knows it would be great!
Howard Jhonson's
Car: 1997 Infiniti J30
The best way is to pry open the whole section where your switches are for the sunroof/light. Very easy just give it a tug and it will come off. Then you will see the switch, just pull it. If your sunroof is stuck open. Just use a hex shaped key and turn it till it closes and your good or you can just pull the fuse near the parking brake, has the map.
