Sunny (Sentra) 1.3 '88 E13S carb empty bowl
minaras
Car: sunny '87 e13s
Hi there, new problem with the carb as now if the car is parked for more than 48h approx the carb bowl is drained! There is no fuel line seen from the glass and the engine needs a while to be able to start. Nikki carbs have a power valve or not? I'm not sure where to start looking... :ohno:
Have you pulled the FSM? If not, grab it here: www.nissanservicemanual.com
That'll give you a start. I suspect you have air entering the system, and I'd check the fuel lines for loose connections (or cracks), starting from the carb all the way back to the tank.
