Sun Visor Question???
banshee08
Car: 2008 Altima Hybrid
Hi all,
I just broke my driver side visor in my 1994 Q45a and I was wondering if a visor from a 1991 Q45 fit? I really need to replace this as my morning and evening drives are both with the sun directly in my eye.
Here is the visor I found on ebay: http://cgi.ebay.com/ebaymotors...ZWD1V
Thanks in advance,
Chan
Fred D.
Car: Infiniti
I dont know if the '91 will fit, but my broke also('94) passenger and driver sides. The plastic housing around the metal pin that acts as a hinge breaks to easy. I have temparly removed mine and now Im looking to fix mine, I'll watch your post to see what you do, good luck.Fred D
banshee08
Fred
The exact same part of mine broke. I just want to replace the whole visor but for now I just used rubber bands to hold The mirror cover in place for now.
-Chan
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There is a great post on the visor post repair by Tangalora in IOM. zerothread?id=50000
Joe has the inserts, but pre-April price rise they were about $57. All the used ones are broken.
Modified by maxnix at 10:27 AM 7/14/2006
FDR Dippin
Car: '90 Q
I've been meaning to post this since last year. I used to have pics, but i think i deleted it. I believe i permanently(?) fixed mine.
I will post what i did, tomorrow, when i'm off, with pics also.I have no solution for any cut wiring.
FDR Dippin
Car: '90 Q
Remove the small plastic cover then these 3 screws
FDR Dippin
Car: '90 Q
I used a small hose clamp, tighten it up good around the broken sunvisor arm, like shown. This will hold the plastic cover that you removed the screws from in place, plus it will hold the visor up once you work it back into the hole in the roof. Between the small nut on the clamp and the "tail"piece that's going to be there once you tighten up, these will keep the visor arm from sliding out of the hold in the roof and bussin you in the head...like it did me.
The blue piece you see is probably not necessary, it was just a small hollow piece of rubber shaped like a cup i had laying around in my car...in it i put some GLUE and capped the end to keep hose clamp on for certain.
FDR Dippin
Car: '90 Q
Put back together and end result is FLUSH.
FDR Dippin
Car: '90 Q
And swivels
FDR Dippin
Car: '90 Q
Can you view 3rd and 4th pic?
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
Can't view ANY of them. It keeps on wanting to upload them but to mo avail.
ddrumman
NOW they are all there.
