Aus94Q45 »
https://forums.nicoclub.com/aus94q45-u136.html
Mon Dec 16, 2002 7:40 am
The rubber seal around the sun roof is not designed to keep all water out of the sun roof tray. It deters water, but the design assumes that water will leak in. The sun roof sits in a tray mounted under the roof. There are plastic tubes that attach to it and are routed to let the water in the tray drain out of the bottom of the car. I noticed a clear plastic tube when I was removing my jack -- this may be one of them. Either the tube(s) is/are clogged in-line, or the rubber seal/silicone that seals the tray to the roof is leaking. I would blow compressed air through the tubes. Your clog may not be at the roof, but down-line or at the exit. If the leak is from the tray seal, then you must remove the headliner and sun roof to reseal. Alternatively, you may choose to seal the outer roof panel opening with silicone and disable the roof motor.
