HashiriyaS14 »
https://forums.nicoclub.com/hashiriyas14-u11745.html
Mon Jul 13, 2009 2:42 am
Why must you all (sans Tiger) continue to fail! Grill things and take pictures of said things!
Anyway, I cooked a steak on the grill yesterday. Well, technically it was on my grill's side burner, on a cast iron pan. This is the way to cook steak. 90% of steakhouses cook steak this way, and then they might *finish* it on the grill or in the oven, but it's much harder to get a good even crusty char on the grill.
Nothing super ritzy, no Prime dry-aged grass-fed blah blah blah, much as I like that stuff. Just normal USDA choice NY Strip from the normal grocery store will do fine if properly prepared. Buy it THICK though, at least 1" thick. I paid $12 for this steak and it was BIG. If you want, you can approximate dry-aging at home, but I'll cover that in a later post.
The pan is already going on the side burner. It needs to be SUPER hot. NO oil in the pan, no nothing. Just cast iron pan + burner on "high". The pan should be SMOKING before the steak goes in.
In the meantime, we rub a little oil, coarse sea salt, and fine-ground pepper onto our steak and let it sit:
When the steak goes in the pan, DO NOT TOUCH IT. Moving it will ruin the char, give it at least 6 minutes on the side. It will smoke like crazy, this is why it's good to cook it outside. You can try this on a pan over the grill, but it won't be as hot as a good side burner:
If the steak is sticking to the pan, it's too early to move it. Once it's easy to move around, then flip it over. Use TONGS, not a spatula, because you don't want to tear the char off the bottom. Once flipped, don't move it again for the same reasons as before. It should look like this:
Obviously, do 4-5 minutes on that side too. Then, pick it up with the tongs and let each edge hit the pan for at least 20-30 seconds to caramelize all the fat along the sides. The finished product should look as follows:
DON'T EMPTY YOUR PAN YET! Your pan has killer beef drippings in it and you want something to soak up all that flavor. This "something" can be anything, but I picked some fresh green beans I'd gotten from a farmer's market earlier in the week. Boil beans first (about 90% cooked), then strain, let dry, add to pan (turn pan to medium first), then grind some pepper and squeeze some lemon juice. Let them caramelize.
Before taking your steak out of the pan for good, be sure to do the "finger" test for done-ness. If it's still soft, you're rare or medium rare. The firmer it is, the more done it is. I like my steaks rare to medium rare, and I think I did a pretty good job:
