AZhitman wrote:I still don't understand why you'd think you'd have a clearance issue... I have 255/50's, stock diameter, and a 1" suspension drop and I have NO clearance issues.
In the 17" tire size, I believe that the diameter is 1 inch larger for the 255/50. The shape of the tire sidewall and the tread width, etc., may have an impact on the tire fitment. I am not sure of this, of course! The true test is to try it.
If the offset of the tire is high (like 45mm), then the clearance issue to the suspension components (particularly in the front) is a concern. Offsets of 38mm to 40mm would probably be safer. Too low (like 30mm or 33mm) and you might have fender clearance issues ... I think!
Again, the true test is to try the fitment.
Z
