Thank you...so I'm assuming this is a bolt-on affair with no mods required?Yellow4g63 wrote:T3/T04E 50 trim with a .63 exhaust housing can nevar lose.
i like the sound of that vg turbine.side waz wrote:The HKS GT2530, 35 and 40 all bolt right up to the RB20 manifold and allow for the use of the stock oil/coolant feed and return lines. The HKS GT2540 will make close to 400hp however it's pretty laggy and not worth the added money over the 35.
It all depends on your budget and what your end goal is as well as what you plan on doing with your car. A series 1 VG30 turbo will also work great, bolts up, uses stock lines and is good for 20psi efficently. My buddy is running one on his Ceferio.
It will bolt on to the manifold, but your going to need new oil feed lin and prob a drain too. The exhaust manifold needs to be modded for the external gate or you could run the gate off the exhaut housing like the DSM guys do.95KoukiS14 wrote:Thank you...so I'm assuming this is a bolt-on affair with no mods required?
I'll let CarlH take this one. I think he was running the 7MGTE injectors on his 20. Yup resistors will be needed. since the stock size is 270cc and going to a 550cc the AFC might not beable to do a good job, but then add a Z32 maf and maybe..... but the Emange is way better but a chip and the AFC could work better. Chip the ecu for the new Injector size and use the AFC to adjust . Again talk to CarlH, I suck at Rom Editor... OH BTW CARLH that VE bin file you fixed for me seems to work pretty good... not sure about the A/F but I'm getting a little more MPG out of a full tank of gas.95KoukiS14 wrote:I have another question. Since I would be upgrading the turbo..I figure I have to upgrade the fuel injectors. I read I can use 7mgte injectors, but I have to wire in resistors (10 ohm?).
Are their any injector upgrades that are simply "plug-n-play" ?
Also read that if I use 550cc injectors....I can't tune the car with something like an S-AFC, but can I use an E-Manage?
TIA
RB20 and 25 are high impedance not low like the GTR. You will need the resistor pack fromt the skyline or wire some inline.s14 2510’s wrote:I plan to run my rb26 stock 444cc injectors in my 20. I have a set lying around so why not. The 26 and 20's use the same resistor do they not? I olney want like 300-350 crank max. Im just building this for a drift car.
Yes you will need to wire in 10ohm 10 watt resistors if you intend to use the 440s out of the 7Mgte. Those are what I put in my 20. I also have a Z32 MAF and SAFC to correct for it, but I would highly advise getting your ECU chipped (like Yellow4G63 said). My SAFC is taking out way too much correction. I plan to get mine chipped for the injectors and MAF, and just tweak with the SAFC.95KoukiS14 wrote:I have another question. Since I would be upgrading the turbo..I figure I have to upgrade the fuel injectors. I read I can use 7mgte injectors, but I have to wire in resistors (10 ohm?).
TIA
