hiimjered »
https://forums.nicoclub.com/hiimjered-u98712.html
Thu May 21, 2009 3:18 pm
What Kolk1 said is true, or, if your amp supports high level input, you could just run signal wires directly to those inputs. Either way, you'll end up running a 4 or 8 gauge wire directly from the battery (with a fuse as close to the battery as possible) to the amplifier and another wire of the same gauge connected to the car's chassis. Then run signal wires from the stereo and speaker wires from the amp to the speakers and you're all set.
Expect to take a good day or so to run all the wires properly hidden behind plastic and under carpet. If you need help figuring out wire colors, you should download the shop manual (available linked from somewhere on this site, do a little searching.) There is also a good how-to on replacing the stereo that has good info that could help with this project.
Hope it goes well.
