Suggestions on a diff
NackolaS13
Car: 1993 240sx Vert finally
Welded the way to go? or maybe a posi diff for under 400 dollars possible
samxini
Car: '95 240sx w/Kouki conversion
2-way LSD
AZ89two4Tsx
This one:
Anyways, the only diff I could think of for around $400 would be a VLSD. Those can actually be found for around $200. The clutch types go for around $600 USED so I highly doubt you'll be able to find one that cheap unless you've got some good connections. And there's always a welded diff if you're super cheap and don't care about tires, noise, etc...
sommmatt
Car: 1989 Nissan 240SX
used S15 helical
NackolaS13
Ive rode and drove in a 240 with the diff welded and dont mind it at all, i just pretty much want to go sideways
AZ89two4Tsx
Then a helical is definately is not for you. It is definately not preffered for drifting.
If you are willing to sacrafice ride quality, wants something that locks better than a vlsd, and are on a tight budget, welded is for you. You can get it for much less than $400 too.
Otherwise, I'd save up for a nice used 1.5 or 2 way.
NackolaS13
well ived talked to a guy about welding it he'll do it for 50, im just not a drifter, have always had front wheel drives, was unsure on spending the money on a diff need suggestions and thanks a lot guys. btw while people are actually responding to me could the flywheel need turned cause the clutch to slip in only second gear
Justin35ll
Car: s13 coupe sr20det
If you're not drifting then don't get a welded. I have one and I don't mind it, but then again it's not my dd so
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
I hope that pic up top is a joke. Some people on here wont think and will weld their pinion to their ring gear.
Next thing you know there will be threads poping up. "I welded my diff, now car is a no go".LOL
Get a pic of welded spider gears up there.
NackolaS13
yeah, it had to double take at it, but the my 240 is my DD and still thinkin im gonna weld the diff
