lol I was lucky enough to get one of the last M-Specs on the market after they were discontinued. I was looking at the differences between the megan racing and tomei manifolds and the tomei seems to be alot better quality. But if people are having problems with the tomei manifolds too I guess I will look for another manifold to buy. Problem is I can´t afford to spend $1,000 on a hks or other big named exhaust manifold. I need something that´s cheap and reliable and that I don´t have to replace every other month. As for the ecu tuning, yes I am going with a enthalpy tune and the safc is for backup.duffman1278 wrote:Good luck getting an M-spec, I believe that their discontinued. Also, you might want to save some money on the exhaust manifold by going megan. People will tell you that megans crack but so will the tomei. Also, as for your SAFC, you'd be better off getting a tune from like enthalpy or jim wolf.
Yeah I will be getting a deleted cat for track days, I will have to look into the meth/water injection. So I´m guessing I should have no problem running the 550cc´s on this setup right?Emperor_Tha wrote:maybe get a deleted cat for track day. Also recommend get meth/water injection since u are planning to run 550cc injectors. So good luck on your build
If your getting a ecu tune you should get bigger injectors for more head room, If you dident know get at least 1 step colder plugs for higher boost and with a built bottom end you should be going for over 350whpRapeacivic wrote: - SARD 550cc Injectors - CP Pistons 86mm - Eagle Rods - Enthalpy ecu tuning - NGK Iridium Spark Plugs
Yeah I think I´m going to end up getting some bigger fuel injectors because I am somewhat unsure about the 550cc injectors. Yes the plugs are 1 step colder. As for 350rwhp it is a hp rating I will would be happy with although if I make more hp even better lol.supreamS14 wrote: If your getting a ecu tune you should get bigger injectors for more head room, If you dident know get at least 1 step colder plugs for higher boost and with a built bottom end you should be going for over 350whp
