AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Tue Feb 02, 2010 5:21 am
If I were you, I'd upgrade just the front speakers and leave the rear stock. I have upgraded rear speakers, but I haven't actually used them in well over a year (seriously, they aren't getting ANY signal). CDs and other music you are going to play in the car is 2-channel, so it seems pointless to try to reproduce it with more than two channels.
Also, I would do the upgrade all at once. Getting good speakers will require an aftermarket amp. If you put the speakers in without the amp, it's not going to sound good until the amp is in there.
If you get speakers that will sound decent without an external amp, a good amp would likely overpower them. I think you'd probably be happier upgrading the front speakers all at once and adding an amp at the same time.
As far as speakers go, I think Doc found a sweet set in some Hertz components (if I remember correctly). But, I don't recall the exact model number. I would think it might be possible to upgrade the front speakers to that set and add an amp for around $500-600. Hopefully Doc can chime in with the speaker model so we can price some stuff out...
