slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Sat Oct 08, 2005 8:02 pm
Hey guys/gals. I finished the install tonight! All I can say is *yum*. I'v never owned a car(this is my 4th) with aftermarket suspension components on it. Sure the AGX/Stech combo might be 'entry-level' or less to some, but wow did it make a difference: even without an alignment. I took [more] corners faster in one hour tonight than I have in the 3years I've owned this car.
Just FYI, I replaced front: strut bearings, paper 'gasket', dust boots, all OEM. Rear: upper spring perches, gaskets, both OEM, both rubber 'bumpers' with NISMO versions, KYB boots.
I also trimmed the bump stops on all boots by < 1/4". Just a little extra headroom(and peace of mind).
I had all intentions of taking lots of pictures, even doing a write-up. Basically the guy helping me was a prick and acted like Cinderella who had to be home by 10pm...anyways, install took us 6-6.5 hours, including two short breaks and pizza dinner.
Everything went on without a problem. Some random tips though: crack the shock/strut rod(center) nuts loose before raising the wheels off the ground. This saved a good bit of headache. Also, some will quickly realize that re-tigtening these bolts is a PITA: the piston rotates. Even on the fronts, with the lock washer, it is not enough to hold torque against. Well for the front, we lowered the car to it's wheels, and this provided enough force to keep the spring perch stationary. Just have another person grip the rod(haha) under the boot to make sure it isn't spinning. On the rear however, they spun much easier. So we had to use a cresent wrench on the rod(very top) and an angled box wrench on the nut to get it 'close enough': they are only torqued to 14 or so ft-lbs, so you can do this easily by hand.
Overall very happy. It was dark so I really couldn't take advantage of the road(unfamiliar area). Tomorrow after the alignment we'll see.
Thanks for the above suggestions, I'll follow up tomorrow night.
