skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Tue Nov 01, 2005 8:59 am
When you say track...do you mean occasional circuit racing? Or drag-racing? Autocrossing? Drifting? Either way, the key word you mentioned is that it's a daily driver, and on a daily driver that is going to see occasional hard-driving--- going with coilovers is overkill. Especially if you live in an area where the roads are rough/poorly maintained. Please check out Chet's (Exar-kun) *stickied* suspension FAQ at the top of this forum. Lots of info in there. IMO, I recommend a good spring/shock setup, either using Koni's or AGX's and replace things such as the tension rods (i'm 95% sure that your t/c rod bushing are shot), and do upgrades like strut bars, sway bars and replace the bushing and key parts that look worn (like the front ball joints, upper strut mounts, etc).
