SeVa-S13 wrote:There's a huge difference between running that much power everyday, versus having a reasonable daily power setting and not being an idiot (stop revving it so damn high) and then turning it up for a dyno or track day.
It's just been my experience that for every engine that blows before it probably should, there are engines that go beyond what anyone thought was reasonable. What's the stock block SR record? Something over 500whp? I've seen an RB20 with crap compression and a horrible tune make 400whp. The only reason that one failed was due to the awfully lean tune. What's the stock KA record anyway? Coulda sworn it was pretty high...
How much power were you making when your engine blew? And it was rebuilt with forged pistons right? I've never been a fan of trying to make any sort of decent power without a tune, and a cookie cutter ECU flash is not a tune.
Of course making any sort of moderate power is never "safe," comparatively speaking; but everyone should know that and realize when they try to push things past what they were meant for, stuff will break eventually.
Of course the highest powered KA I've ever personally owned was a 300whp-ish nitrous single cam, but the thing had 180k on it and was abused by its previous ricer owner. But I know there are others that have gone far above and beyond that and are still doing so. I think a good stock rebuild with a daily low boost setting in the upper 200's with a high boost at around 350-375whp on rare occasion would be pushing it if you wanted the engine to last forever, but feasible. Just stop redlining the damn engines. (Sorry, people redlining KA's is a pet peeve of mine)
Okay, this is what angers me about forums...No one ever admits they're wrong. You said a stock block rebuild should be able to have 400whp "safely," and have since added numerous qualifiers to that statement instead of just admitting the fact that, in its original text, the statement was prima facie WRONG.
You're right, there's a huge difference between being a dyno queen and making x amount of HP for 30 seconds, and actually driving with that much horsepower every day; but the person who started this post was clearly NOT looking for an engine that can hold on to the ragged edge of its limit to make the most amount of hp; if he's considering using forged pistons and a different head gasket at only 250 hp, he's clearly interested in longevity...I don't know anyone who ISN'T interested in longevity or durability, unless they're building the car purely for dyno or drag purposes (and the vast majority of us simply do not have the funds nor time to do so, barring people like Ivan). The stock block records are entirely irrelevant to this post. He's not trying to make the max amount of horsepower before it invariably blows up.
As far as being an idiot and not revving so high, I hope you're not referring to me. I've never over-revved my engine, rebuilt or stock. When my rods decided to exit fashionably via my block, the engine was at 3000 rpm in 5th gear; everyone agrees that is a comparably low RPM. Even with a valvetrain and connecting rods/bearings that can handle it (as mine now can), i'd still not rev past 6500 rpm simply because it's not reliable.
My engine was rebuilt with EVERYTHING sans connecting rods (forged pistons included) when it blew, and was at about 16 psi from a small T3 (>300whp for sure). When the engine was torn down for rebuild the builder pointed out to me that one of my pistons had completely destroyed ring-lands; this was at around 10 psi.
As far as tuning goes, the WHOLE PURPOSE of "cookie cutter" JWT ECU's is precisely that: so the owners don't tinker with the tuning themselves and then end up blowing an engine up; hence the reason why the fuel maps and timing is CONSERVATIVE....Of course the JWT ECU isn't the best "tune," as far as power goes, but if you're defining the best tune as the most power (which will always be under far leaner conditions and aggressive timing than the JWT ECU allows), then the best tune is most ASSUREDLY not the most reliable. The best tune for the max amount of horsepower does NOT mean the most reliable tune. This is a huge distinction that many fail to see.
You admit yourself: "Of course making any sort of moderate power is never "safe," comparatively speaking; but everyone should know that and realize when they try to push things past what they were meant for, stuff will break eventually."
But the fact still stands; you said 400whp is achievable safely on a stock block KA rebuild. This is completely false, and that's all I'm trying to get you to admit.
We need more people like 420sxse on the forums who aren't living under some fast-and-the-furious illusion of being able to create unlimited power on a stock engine designed for natural aspiration and low power levels. Again, let me repeat: I, as well as the vast majority of KA owners, and the person who started this thread, are interested in durability, and longevity; and neither of those conditions result from using stock pistons and stock connecting rods on a KA.
