I'm about to run through some of the "first things first" kind of maintainance that needs to be done on my Z. Because i just bought it... i want to get everything i can think of that needs to be done or should be done taken care of so i'm at a fresh-starting block. Plus i dont wanna make modifications to an engine that isn't in tip top shape.
Here's a list of some of the stuff i have planned so far.
120k Kit contains:
3 Drive BeltsWater Hoses (Quantity 2)Crankshaft Sprocket PlateWater Pump & Water Pump GasketCamshaft O-Ring Seals (Quantity 2)Camshaft Oil Seals (Quantity 4)Tensioner Springs (Quantity 2)Timing Belt TensionerThermostatBelt Tensioner StudIdler Pulley & StudSecondary Idler Pulley & Stud
This one is from
http://www.courtesyparts.com ... @ 506.72
Some other things i want looked at and replaced unless they appear brand new or in really great condition:
EGR and PCV ValvesFuel DampenerA/V Valve AssemblyVapor Lines, Brake Lines (you guys recommend upgrading to some kind of aftermarket high speed stainless or braided lines?), + cambles, rear main seal, any other readily visible places for potential leaks.Install Speed BleedersBrake pads/rotors, Air/Oil Filters + oil change.Transmission Fluid and differential gear oilSteering gear/linkage, axle, and suspension parts.Spark Plugs, Fuel Filter, HICAS Linkage.Exhaust Components (checked for leaks etc.)All hoses, vaccum lines, wires/harnessesThrottle Bodies(more than likely just thourougly cleaned)Oil Pressure SensorInspect Sprockets for wear/tear/cracks or damage.
After all that...Compression Test, Fuel Pressure Test, Boost Leak Test (better not be one after i replace all the hoses, etc.), Make sure mechanical timing is dead on, Then of course a 4 point alignment.
Anything i might have missed... please fill me in... or tips on anything i've mentioned... i would greatly appreciate.
Also any recommendations for the intake parts? I might as well upgrade to some snazzy aftermarket stuff... any favorites?
things i have already done...
Newly rebuilt transmission still under warrantyNew radiator, new injector wiring harness, new water temp sensor, new valve cover gaskets, new telescoping antenna, new battery, new PCV hoses, And it's also had the conversion to a R134-a coolant system.
