ca18det_boy »
https://forums.nicoclub.com/ca18det-boy-u12172.html
Mon Aug 07, 2017 9:47 am
I agree with Larz that some things are better left to the dealer to diagnose, however this one you can test a bit before you shell out the dough to a dealer. My gut is saying master cylinder, master cylinder, master cylinder. Here is why, if your booster goes out the typical symptoms will be a hard pedal. Your car will still stop, but you'll have to press like hell to get it to slow down quickly. If the master cylinder goes out, you'll lose the pressure needed to apply the brakes and the pedal will fall to the floor. Now it is possible to pump the brakes and it will build up enough pressure to stop the car, but for the most part your pedal will feel spongy. Here's how you can go about figuring out if either of those parts are bad:
Booster: Start the car with your foot relatively firmly on the brake pedal. If the pedal falls a bit, this is a good sign. If it doesn't fall, then you're looking at a possible booster issue. Next, go under the hood. If you have a hand held vacuum pump you can verify that the booster is holding vacuum. You'll find the exact measurement in the FSM for what it's supposed to hold. You want to check 4 clamps (1 where the hose goes to the booster, 2 at the check valve that is inline most likely about 4-8" away from the booster, and 1 at the other end of the hose where it connects to the intake manifold.
Master cylinder: Verify no leaks at all lines going to the master cylinder and at all brake line joint locations. Check fluid to verify there isn't any debris in it (I.E. torn seal particles), Check for fluid/missing paint around where master cylinder bolts to firewall, check for fluid/missing paint inside of the vehicle where master cylinder comes through firewall. If all of these checks look good, lets bleed the brakes to verify no air in the line. Start farthest away from the master cylinder and work closer. Passenger side rear, drivers side rear, passenger side front, drivers front. When you bleed the brakes, if you're not able to build up pressure after its done...then you have a bad master cylinder.
Doing these tests will set you back about $7 for brake fluid and you can find a vacuum pump for maybe $15. $22 is a hell of a lot cheaper than $180 and you'll know what is actually going on.
Now, if everything checks out and this was just an isolated incident then I would tend to believe that the brakes were overheated due to excessive braking. This is a whole different story, but could account for why the pedal lost pressure 1 time. With brake fade you'd be looking for glazed pads and hot spots on the rotors.
Keep us posted on how things turn out and good luck!
