nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu May 26, 2011 10:56 am
You know, may be possible. Since you have the hose off I would definitely replace them , maybe even the pcv valve itself as well if unsure the last time it has been done. The rattleing in the pcv normal, if it doesn't that means its not working. I am still pretty sure there is a leak from the engine, have you checked the valve covers, maybe by the VTC solinoids? If the gaskets are old, they like to leak, and sometimes its unnoticeable unless you take a few things apart. If you can, try adn run your hand along the back side of the engine, see if any oil build up is occuring. There are so many places that this engine can leak, especially coolant if the lines under the plenum have not been deleted.
