Sudden Pop-up lights failure .
Spawn_CA18
Car: 1993 EDM Nissan 200SX S13 CA18DET & 1995 EDM Honda Civic Crx Del Sol EG2 B16A2
Hello there guys ,
Yesterday , when i try to turn on the lights , pop-ups doesn't popped-up and only right headlight gets on when they are down . i lift the pop-ups with using long-range lights and they stay up . but if i close all lights and open them again they don't lift up.
Basicly : (chronologically)
- Normal lights - Pop-ups doesn't move(stay down) - only right headlight is on
- normal light switched on + Long lights - Pop-ups lift up and stays up - only right headlight works long and short - left headlight not works
- normal lights - pop ups stays up - only right headlight is on
- normal lights switched off , pop ups comes down normally .
Another point :
when all lights are of , i open long lights and hold it with , pop-ups comes up and down again and again endlessly.
i don't understand why together left headlight is gone and pop-ups doesn't get up . also left long range lights are doesn't work too..
i hope i explained it well
i will record a video tomorrow
any suggestions ?
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
Change out the headlamp relays with known good working relays and see if it still doesn't work.
Mine went bad during the year that that my car was off the street getting the ca18 put in.
Spawn_CA18
i will check out the relays , but i m not sure which of them is pop-ups relay
cbh148
They're in the front corner of the engine bay, near the air filter. I think it reads "Headlamp Retract" or something like that.
Spawn_CA18
ok i will check them ,
but why pop-ups work with long-range lights , but not with short-range lights?
cbh148
I don't know, mine did the same thing but I switched the relay and haven't had a problem since.
dc1984
Car: 93 240sx/98 180sx blacktop sr20det :RIP/ 93 jeep grand cherokee
ive always battled the issue where one of my headlights wont go back down and everything else works fine. its been an off and on problem since i ought the car in 2004. never figured out what it was.
lately, ive just kept both headlights up.
Spawn_CA18
dc1984 wrote:ive always battled the issue where one of my headlights wont go back down and everything else works fine. its been an off and on problem since i ought the car in 2004. never figured out what it was.
i think i know your problem , if you are sure on relays , just check a little brown connector that attached to light control switch on steering colomn . or try to check headlight timer .
by the way , my problem is still on , i tried wverything today . but no answer
Edit : oh s#!t i didn't checked headlight timer :D
Edit 2: checked now , it seems good , no change
