VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Jul 11, 2024 3:23 pm
Alternators don't usually short through the main terminal. In theory they can, but usually they short through a diode or field winding and draw about an amp. Radios are prime culprits for draws as well, both the head units and amplifiers, but those also usually draw no more than a couple of amps. For a 6 amp draw I'd think you'd be looking at something in the engine box, maybe a stuck ignition relay.
Note that your ride has an SEC (Smart Entrance Control), which is the prehistoric ancestor of the BCM. The SEC is always awake, so you can't get an accurate draw estimation without letting it hibernate. Modern Nissans mostly hibernate at 30 minutes on the dot, but earlier implementations usually time out at something between 10~20 minutes.
