candela »
https://forums.nicoclub.com/candela-u13584.html
Thu Mar 25, 2004 1:06 pm
http://www.nissaninfiniticlub....57086
as you can see there are aftermarket bars that are larger...I know bigger isn't always better and lots can be noticed (assumign everything else is top notch) from going larger. Its not just that few mm increase... its a percentage in stiffness. I really do not know the ill effects of going a little to large as usually sticky tires, tire pressures, suspension settings...etc can make up for the rear wanting to come out from that bar. Check out that thread though, good luck!
