Ramondo »
https://forums.nicoclub.com/ramondo-u43524.html
Tue Aug 28, 2007 6:39 pm
You guys on the NICO forums are the greatest!! After reading some of the forums I decided that I really needed to do my timing chain guides. I have a 1993 Q45 that I bought new in December 1992. It now has about 87,000 miles on it. I keep the oil and filter changed every 5,000 miles and have not had to do any major work on the vehicle.I got the parts kit from Infinity of Scottsdale, read the tech articles again and started to work. Keep in mind I am 64 years old, so things go a little slow. When I took things apart I noticed that all RTV (water pump, thermostat, valve covers and front engine covers) was light blue. The old timing chain guides were indeed plastic, but were as good as new, no cracks and not brittle at all! After changing the guides, I used a drill to rotate the oil pump until lots of oil was squirting out around the chain area. I turned the engine over several times using the 30mm socket on the crank pulley. I then reassembled everything, put in new fluids and held my breath as I tried to start it. To my surprise, there was no loud noises and it started and ran smooth and strong! I couldn't even find a leak anywhere. Thank you NICO guys! I have loved my Q from the day I bought it and I love it even more now.
