ZMQguy »
https://forums.nicoclub.com/zmqguy-u270475.html
Fri Apr 07, 2017 11:16 pm
Another update, so far I can tell you that the "Godspeed", and presumably other, 370z adjustable upper control arms are a direct fit bolt on. The Godspeed ones are cheap though and will need some work when they arrive. I recommend doing this before you mount them on the car. They will need some of the paint removed from where the ball joint slides and will also need some paint and possibly some material removed from where the screws go in. I highly recommend doing this first. It's a much easier install if you make those slight alterations on a workbench. Also, if you are running tein h tech springs the controller arm bolts will hit the springs and won't come out. I used a spring compressor to slightly move the coil that was preventing the bolt from being removed. No alignment yet. That will be coming on Wednesday afternoon.
