Successful ECU Reset
SamBlon
How do I know I did the ECU reset without disconnecting battery successfully?
I did the reset based on the instructions in the FAQ's
Took me a couple times but got the timing down and SES light to blink and finished the reset. I actually ended up just shadowing the youtube video to get the timing.
After starting the car I still had my trip odometer reading the same and all radio stations were the same. All settings were like they were before the reset.
Was anything even supposed to happen or did I do it right?
Ilya
Those things aren't reset with the ECU. That's all likely BCM, etc. If you got the same result as the video, you're likely fine. I personally would just get a bluetooth OBD-II connector...much easier to reset the ECU, force tests to re-run, etc.
SamBlon
Thanks will do
SamBlon
Which one do you use?
Ilya
