Successful Bose system swap to android head unit in 2nd gen Rogue?
Progen
Car: 2015 Nissan Rogue SL w/ Premium Package
Mods: Clear LED Taillights, LED Foglights, RGB footwell lights (OPT7), Red trim all around interior.
has ANYONE done a successful swap from the 2nd gen BOSE head unit to an android head unit at all?
I see units that replace the non bose head unit/navi... but not sure if the same thing applies to the bose units as well. Emails to the sellers have yielded no response.
Hopefully with the around view moniter/back up cam, radio, and steering wheel controls working? (fully functional, in other words)
If so... how hard was it? pics/experience/model/brand?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Rogue One wrote:
Fri Feb 17, 2017 7:39 pm
Yeah, the process is going to be about the same as it is for the 1st gen Rogue. There are extensive write-ups listed on the Rogue home page rogue-forum.html
You can also use the SEARCH feature on this forum to find out more.
IIRC when someone asked about this for the 1st gen, the around view system is proprietary. I did receive replies back from at least two different aftermarket manufactures (I think Pioneer was one) and none of the major brands makes a fully compatible unit. You could try contacting MXTRON to see if they have a newer more compatible unit available. Another member successfully installed this brand in their 2016 mxtron-stereo-replace-for-rogue-t608880.html
SHAYE13
Car: '13 Nissan Rogue
T32 Nissan Rogue OMG LOL
I posted something similar on fb last time
I tried and it works with oem steering controls / bose amp/around view etc
https://phoenixandroidradios.com/collec ... -2014-2017
Progen
SHAYE13 wrote:
Mon Oct 09, 2017 10:29 am
Thanks! I was actually looking into that one. which one did u get? Octa core or quad core? Did you happen to do a write up?
Progen
holy crap, they have a vertical one too! lol
Is it safe to assume that you'd either have to have wifi in your car or connect to your phone over a hotspot? How easy is it to put wifi in the car? has anyone done it before?
SHAYE13
Progen wrote:
Wed Oct 11, 2017 8:13 am
Noi havent been able to contact the seller
been a bit busy lately with midterms and getting other things like new winter tires +some maintenance
Dont order yet if you havent
I may get better prices for the system
mitchrogue
Car: 2016 Nissan Rogue
I just installed an MXTRON unit in my 2016 SL. Everything works, except for some crackle in the speakers, which MXTRON says is likely due to the amp out to the Bose unit, but they don't have much experience with Bose systems. Very nice overall. 360 camera and steering wheel controls work and using an adapter you can re-use the OEM GPS antenna on the roof. This is the one I got: http://mxtron.com/products-detail.php?ProId=7
mitchrogue
So, the crackle isn't in the speakers, it's actually in the bose amp under the passenger seat. Anyone have any ideas for a fix?
Return to “Rogue Forum”
