subwoofer
ddaltonttucker
Car: 2001 nissan pathfinder 4x4 se
i drive a 2001 nissan pathfinder and i want to replace the stereo head unit and i would like to add a speaker box with 2 subwoofers and 2 tweeters but im not sure if this is possible i want to leave the stock speakers and amp if possible i dont want to rewire all my speakers so if anyone has any ideas please let me know
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
It will be easier to run new speaker wire everywhere than to bypass the factory amps *and* add two subwoofers, in my opinion. The stock speakers suck, too.
Azndjay
2008 Acura TL type S
2003 Acura RSX
yes, you can keep all factory speakers and amp. and you can add new head unit and also add aftermarket amp while leaveing your stock amp. you need those two adapter tho.. i have the PAC ROEM-NIS2 works great got rid of the crappy cd chager...
PAC ROEM-NIS2
System Interface Kit to Replace Factory Radio and Integrate Factory Amplifiers for 1995-2002 Nissan Vehicles with Bose Audio Systems
http://www.sonicelectronix.com/item_111 ... -NIS2.html
System Interface Kit to Add or Replace An Amplifier in All 1995-2002 Nissan Vehicles with Bose Audio System
http://www.sonicelectronix.com/item_771 ... -NIS2.html
ddaltonttucker
i already have the wiring harness for the radio and an adapter kit for the dash so do i still need the first adapter?
Azndjay
2003 Acura RSX
well if you got the adapter i think you only need one.
the second adapter that i shown is for adding a amp with a stock stereo head, but since you got the first adapter and an aftermarket cd unit your good to go on adding a amp since you already kept your stock speakers with the adapter you have now. if that make sense
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Has anyone had experience with the PAC adapters??
Azndjay
2003 Acura RSX
GRNMACHINE wrote:Has anyone had experience with the PAC adapters??
I have it there great easy to use, if u can wire a cd player to a car then u can do the pac adapter.
worth every penny to replace the dumb oem cd player that keeps getting stuck
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
