I would also reccomend a 12.5 BA-pro, but he seems to be leaning for 2 10's...
Sorry to hear about your ED 10k but I have a cpl of questions.
What revision of E10k did you have?Box sizeBox constructionwattage
I have a e10k (3rd version IIRC, domed cone and dustcap), seeing about 350 wts rms. Its sounds nice and tight in a .57 before driver displacement sealed box with about 8 - 10 oz of fill to accentuate the low a very slight bit.
My box on the other hand is constructed out of 3/4" 13 ply baltic birtch, screwed and glued with polyurethane constrution adhesive. Then I proceeded to wrap the box in fabmat (woven roven - 24oz roven fibeglass cloth stiched to a heavy mat), and used over 40oz of resin total in it. The glass work weighed as much as the wood did.. Then I coated the inside with resin and a couple layers of undercoating spray.
Um yeah overkill but when you knock on the side it sounds like metal, without the audiable down falls of using metal for cunstruction
As far as terminals go, I havent seen or heard that they didnt come with them??? Care to explaine?
