subwoofer problem
Post all your Nissan electronics, car audio and stereo questions here!
silk240
Car: '92 white 240sx coupe w/ blacktop sr20det
i have a 8" duel voice coilover sub and a 200 watt amp wired up, but the sub also plays regular music through it. why is this and how do i fix it? the duel voice coilover is wired parallel.
TakedaT
Car: 1999 Infiniti I30 Limited
When you say "regular music", I'm assuming you mean highs and mids. Somewhere in your system, you need to have a low pass filter. It could be on the amp (most likely), or anywhere like the head unit, EQ or some kind of passive crossover. More details about your system would help get better answers. For now I would look to see if your amp has the low pass crossover built in and make sure it is on.
xekushnr
Car: '90 Nissan 240SX Hatch
The low pass filter should be a dip switch on the side of the amp. Switch it on, then adjust to what frequency you want all sound above it to filter out.
silk240
the amp im using is an older model and the only adjustments that i see are for max or min power. then there is a button that if i push it it does nothing to the sound. everything sounds the same is what i mean
audtatious
You need a filter of some sort. There are three ways to do it.
1. Passive: Speaker level device comprised of coils and resistors2. Active: Line-Level (RCA) device that filters the music before the amp3. Radio: If you have a sub-out RCA set, run that to the amp
silk240
changing out the amp would not solve this problem? where can i find those two items you just mentioned.
audtatious
I believe Circuit City/BestBuy can get you either passive or active crossovers. Yes, swapping amps to one with appropriate filters would work as well.
silk240
aight, thanx
Looneybomber
Car: 02 explorer sprt (grn)
10 G37S (white)
*edited because I used the word passive instead of active in the first line*
I recommend going with an ACTIVE (not passive) XO as opposed to a passive for two reasons.
1) Active XO's allow for a much greater flexibility because you easily change your XO frequency with a switch or, in most cases, a small dial.
2) High power components will cost quite a bit of money. Without them, you risk burning your XO, though with 200w, you wont need super high power components.
Modified by Looneybomber at 11:13 PM 7/8/2007
silk240
will best buy carry something like that you think? or do i need to go to a special audio place
