AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Mon Oct 06, 2008 9:03 am
You can use the controls on the amplifier to adjust the settings for the subwoofer. Also, if you are going to use a line-out converter, you should be able to make some basic adjustments on there. You will not be able to directly alter the subwoofer's settings from the head unit. You can increase overall bass, but I'm not sure what frequency range this boosts from the head unit.
