95silvia14 »
https://forums.nicoclub.com/95silvia14-u40913.html
Sun Jul 12, 2009 1:08 pm
first of all it will not take the lows away from the rear speakers what you have to do is go into the radio menu and take out the bass and if you have it turn off loud, now the problem is with the subs if you dont have a sub catagory on the menu it will take the bass out of the subs and they wont hit as hard. as for to install you will need about 17ft of power wire 4 ft of ground wire, 17 ft of rca and a remote wire to turn the amp on. when your running your wires. you want to take the rca's and remote wire and run them down the oposite side of the car that you run the power wire on to avoid pulling engine noise threw the power wire.
