Elmojo »
https://forums.nicoclub.com/elmojo-u45146.html
Sat Oct 28, 2006 1:13 pm
Hi All,I've been thinking about the possibility of adding a powered sub to my V without replacing the head unit or monkeying around too much with the OEM wiring.Here's a possible solution:If you look in the the rear cargo area, on left, right next to the interior light, you see a small squarish panel. Pop that off with a small flat screwdriver, and you have access to the area where the wires for the upper light of the left rear taillight connect. We know that the factory subwoofer mounts in this area, so it stands to reason that the OEM pre-wiring, if it exists, would be in this area.Poke around a bit, without breaking the white plastic clip that holds the taillight plug loom to a mounting screw (don't ask how I know this), and you see a nice empty plug, taped to another wire loom, doing nothing. Aha! Here's our subwoofer connection!I spent about a half-hour with my multimeter and a notepad, and the following jpeg is the result...I've contacted several electronics suppliers to inquire if they might be able to help me find the female end of this funky plug, but it looks pretty proprietary.However, you'll notice that all the wire ports aren't used, which bodes well for there being other Nissan applications that use this same plug. Does anyone recognize this plug?If we can find the female side, it should be fairly easy to wire up an aftermarket powered sub without hacking our wiring.Can any of you audio-geek types look at the outputs I mapped and suggest what each of these wires might be for?I assume that the two 12.5v wires are power (duh) and remote, with the remote being the blue one that stays energized when the ignition is off, but I could be wrong. The other issue is that almost all powered subs I've found have only line level (RCA) outputs. Is there a simple way to convert these to the speaker level inputs that we'll need to use the factory wiring, or do you think that some of these ports are in fact line level already?
Comments and ideas welcome, let's make this work, I need boom in the hatch!
Elmojo
---Click on the attachment link to see a legible version of the diagram---
