jsturges18 wrote:at this point you should just remove the whole system and redo it. ive never heard of anything like this i wonder...are your speaker wires hooked up the right way? how are you running the sub and amp? 1 channel? 2 channel bridged? svc? dvc?
If system you mean just the amp and sub part, yes i did this. I didnt do the head unit though as theres no need to. The only thing i did was the remote wire to the head unit, since everything for the speakers and head unit itself is fine.
My speaker wires are hooked up fine. The sub and amp is like so
The remote wire comes from head unit under the shifter and center console, past the back seats, to the amp.
RCA wires are from head unit, underneath everything to the amp, the same way.
I have the battery right behind the back seat on the passenger side, and the subwoofer on the drivers side. For power, i have the wire coming from the positive terminal, through a fuse, to the power on the amp. Then i have the ground from the amp, to the same ground as the battery. Its been like this for over a year and has always been fine.
For the positive and negative channels on the amp, there are two. They are currently bridged, positive on one channel, negative on the other channel, like so. The positive is on the left channel, and the negative on the right channel.
l
+l-l l+l
-l
I have the positive from the amp channel to the positive on the sub, and the negative to the negative. I tryed making it so its not bridged, and just running on a single channel, and this didnt change a thing...
and as far as svc/dvc, its a single voice coil kicker comp.
so with this being said... im completley lost on whats wrong.
