Okay so the Kinetik HC16V (KHC-16) will fit in the Q?ganesh21 wrote:The alternator is rated at 110 amps (around 2500 rpm) and 60 amps at idle.
How much is the voltage dropping while playing the music at around peak. If it is below 12 volt - I would be cautious because that could damage the amps.
I would recommend the following:
The big 3 first - this should help with voltage drop
Upgrade your battery - I would skip optima. Go for Kinetic 1600, XS power, SHURiKEN, stinger battery
below is link to battery within 1200 watts rms -
http://www.sonicelectronix.com/viewcat. ... 7_max=1600
You're right. I was copying NPORA's forum sections - they list 1986.5 - 1989 as the "2-door" section. That probably includes 1986.5 D21 Hardbodies. Courtesy Parts also lists 1987 as the beginning of the Pathfinder, so I'll correct my information thread.Chuck Tribolet wrote:A 1986.5 Pathfinder??? Not in the US, I don't think so. The first Pathfinders hit the US about September of 1986, which is normal model year change-over time. They were advertised as 1987 models. I bought my first one Dec 31, 1986 about 1130 pm. 30 minutes later and I couldn't have taken the sales tax as an income tax deduction.
Chuck
It will fit. I had a Kinetik 2400. It fit without a problem.asnorton44 wrote:Okay so the Kinetik HC16V (KHC-16) will fit in the Q?ganesh21 wrote:The alternator is rated at 110 amps (around 2500 rpm) and 60 amps at idle.
http://www.sonicelectronix.com/item_131 ... HC-16.html
