sixxdeuce »
https://forums.nicoclub.com/sixxdeuce-u511.html
Thu Mar 03, 2005 10:00 pm
So I am attempting to make something similiar to the subframe tilt spacers that spl sells (different from the normal collars and spacers), ghetto style. Here are some pics of what I have so far.
text from spl's site to explain how the spacers work:Subframe bushing spacers are used to tune anti-squat by rotating the instant center of the rear suspension through rotating the subframe or moving the subframe relative to the center of gravity:
For maximum anti-squat (eg. drift), rotate the instant center up by installing spacers below front subframe bushing and above rear subframe bushings.
I plan on installing 1 or 2 more washers on each bushing to further rotate the subframe and compress the rubber bushings some more, and I may remove the single one pictured on bottom since it may defeat some of the transfer of the spacers, original thoughts was that it would help compress the rubber but I think thightening with the extra spacers in ther will work well enough, and spls' kit does not use anything on the opposite sides.
