Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Thu Jan 24, 2008 10:08 am
you can use the differential too. its a VLSD, and if its in working order, it would be good to swap over. 5lug, check, brakes, check... but be careful about the rear ebrake setup, it can be a pain to get working properlyon an s13 you can use the aluminum rear uprights, but you have to get coilovers fitted for an s13 but with z32 lower strut mounts (splparts can hook you up like that on their KTS coilovers)
i don't know if the diff is a direct swap, maybe someone with some experience can chime in.i think there is also a writeup on ka24development.com
