SX APPEAL »
https://forums.nicoclub.com/sx-appeal-u20552.html
Mon Mar 21, 2011 11:17 am
With solid aluminum bushings, there's not nearly as much room for play between the studs and the subframe, so you have to make sure you've got the subframe completely straight as you're jacking it up under the car. If one side or end is just a little too high, the studs wont line up perfectly and it'll get stuck. Drop it back out of there, make sure its completely straight, then jack it back up VERY slowly, always checking to see that the subframe is at the same level on the studs at all four corners. What I actually did with mine was just strip the subframe down completely (No diff, axles, suspension, anything) and just got under the car and lifted it into place by hand. Its not that heavy when all stripped down like that, and it made maneuvering it a lot easier.
