Lt.Mike »
https://forums.nicoclub.com/lt-mike-u20681.html
Sun Dec 12, 2004 8:44 am
I purchased the nylon ones off of ebay and they work great. I had to modify them to look like the SPL ones because in order to install them you need to drop the subframe to install the upper part. I turned them into the slide in ones.
If you do not mind dropping your subframe, the nylon ones work just fine and costs less. Quality wise and ease, get the SPL aluminum ones.
Installation takes less than an hour (if you have air tools) or 2 hours like me (all hand tools).
After I installed mines, I could hear the clutch engaging, the movement of the gears in my transmission after I shift, and exhaust piping vibrations.
The gain that I got is that my car (1989 fb) became noticibly more predictable during hard cornering since excessive play in the subframe got reduced.
Great modification overall.
