Second Shadow »
https://forums.nicoclub.com/second-shadow-u4629.html
Tue May 11, 2010 6:49 pm
I originally put solid bushings in my subframe then switched them out to polys. they don't massively effect ride quality(they do a little), but the biggest thing I noticed was the vibration and the noise it caused. to me it felt kind like the way a gravel rode feels but on regular streets, not quite that bad but, well it's hard to explain I guess. didn't like it anyway.
I like the polys a lot. the vibration is low enough to not bother me but it just feels solid in the back. it was explained to me once that for street driving, whenever bushings are concerned, you can firm them up or remove most of them(in favor of solid stuff) but you need some give somewhere between you and the source of vibration or impact, gotta have a buffer somewhere.
so my personal suggestion is get poly subframe and dif bushings. for the RLCAs, if you go with poly subframe bushings you can do either, but if price is bothering you I think your alternative is fine. you might also want to consider boxing your RLCAs, cheap way to reinforce them.
just my opinion.
