gumby74 wrote:80ft/lbs? I did not have a service manual when I installed mine, so I torqued the nuts to 100ft/lbs. I should probably find the correct torque value. I have also been thinking, the humming noise I mentioned after install, could a rubber lining be made for the upper part of the collar? I received my spring silencers yesterday and got to thinking how hard would it be to apply something like this to the collars? If anybody knows about rubber, plastic, cardboard, hell anything that could be applied to the collar or chassis itself I would be really interested. Btw, good clean install.
It's actually 72-87lb, so I did 80lb. You should do it right because if you over torque them, studs will be stretched slightly. If you try to remove the nuts later, you might break them if they are rusty. You know what I mean? Torque spec is very important, so take care of them ASAP.
Basically, this could happen to you later if you try to drop subframe again for some reason.
zer...20477
Good material would be this... You know that thin paper like ring that goes in between strut and strut tower? That's there to prevent metal to metal contact. If the noise bothers me too much, I'll do something about it since it's an easy job to take the collars out and put them back in.
