OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Wed Mar 11, 2009 3:48 am
Well if you do new bushing your need a press and to drop the subframe. But you can use subframe collars and all you have to do is get under the car and loosen the bolts. This method is cheap and very easy. I would also check your axle bolts, diff mounting bolts, and driveshaft bolts. The drain anf fill your trans and diff.
Subframe collars cost about 50 bucks for the named brands.
