subframe bushings
lancet913
Car: 1996 240sx se
KA24DET @12psi
Has anyone used the nismo rear subframe bushings on an s14.Mine are shot, I get a real bad pop when I reverse, and let off the gas to shift up from 1st to 2nd. I didn't know if it would be easier to install the aluminium bushing spacers or the nismos.
mattrcspeed
Car: 95 240sx
i used spacers the 8 pice set it works grate no movment at all
lancet913
Car: 1996 240sx se
KA24DET @12psi
Did you use the ebay ones or a more reputable company?
rudee023
Car: '03 Infiniti Q45
Figured I'd chime in being as I just finished replacing my stock bushings with solid aluminum bushings from NIP. (Not collars) Let me just say that depending on how far gone your stock ones are, you may not be able to use the collars. Mine were completely separated into two pieces. Anyway, dropping the subframe is the easiest part. Getting those SOB's out are a *****! I can give you driving impressions after this weekend. If you do decide to do it, invest in:
1. A sawsall w/ bi-metal blades.2. A good chisel3. A BFH (Big freakin' hammer)
I dropped something.
If your bushings look like this, collars are not an option.
You'll get the hang of it after the first one.
New bushings installed
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
^^^ is that honestly your sig? if it is you need to resize it fo' sho'
E7-S14
Car: ess 14 foo!
TJG wrote:^^^ is that honestly your sig? if it is you need to resize it fo' sho'
take that authority!
I actually Just ordered my Nismo Subframe Insulator Mounting bushings(technical name) today.
I bought subframe spacers a while back.. found out my subframe bushings wer shot.. so sold em.. and decided ot go with the Nismo pieces..
no idea which is easier.Id say the aluminum are easier to press in. since you use a big *** hammer to do it.the Nismo ones you'd have to be more carefull pressing them in.
Modified by E7-S14 at 6:28 PM 1/11/2008
lancet913
Car: 1996 240sx se
KA24DET @12psi
Mine are far gone, if I release the clutch fast in reverse you can see the subframe move down about 2" and pop. I will for sure be investing in the nismo Insulator bushings then.Thanks for the info fellas.
mattrcspeed
Car: 95 240sx
yea i had the same problem just get thes and it stops http://cgi.ebay.com/ebaymotors...photo and thes ar beter cuz they have a pice of them cut so you dunt have to remove the entire subframe
nwmrkt
Car: S13
imo i wouldn't do the collers...it only kinda solves the problem for a time period where as new bushings....
E7-S14
Car: ess 14 foo!
mattrcspeed wrote:yea i had the same problem just get thes and it stops http://cgi.ebay.com/ebaymotors...photo and thes ar beter cuz they have a pice of them cut so you dunt have to remove the entire subframe
the collers don't solve the problem if you bushings are like this
rudee023 wrote:If your bushings look like this, collars are not an option.
thats the reason why I sold My collers in favor of Nismo subframe bushings.
collers only compress bushings.soo.. your bushings have to be in good shape for these to work.
just trying to clear things up.
lancet913
Car: 1996 240sx se
KA24DET @12psi
I most definitely will install the subframe bushing from the nismos thanks for all your help fellas.
mattrcspeed
Car: 95 240sx
actualy they doo my wer wors then that and it fixed the problem
E7-S14
Car: ess 14 foo!
mattrcspeed wrote:actualy they doo my wer wors then that and it fixed the problem
how do you know if you didn't drop the subframe?
anyway.who knows. weirder **** has happened.
mattrcspeed
Car: 95 240sx
i put the car up on the lift and put it in revers and lightly poped the clutch and a frend was looking it if moves or not and u also can hear it
540sx
Car: Nissan 240SX
How do you like the bushings?
I just ordered them from nip.Seemed like a good deal. Did you install the hard rubber bushings that come with them?
johnnycham
anyone know what shop i should order some bushings?
jdm_hero
I just got my nismo bushings in today, I'm not looking forward to putting them in but the ride quality I have with shot ones is starting to piss me off alittle lol.
