subframe bushing
pat93
I'm looking form non-aluminium subframe bushing (not collar/spacer/insert) for s14 1996.
Anybody pls. recommend me the good ones?
180fan
Car: 89 fastback
nismo. call your dealer for the nismo bushings for your subframe.
MAGILLA
Car: 95' 240 se
the peak spacers are polyurethane
oimoit
Car: S14 Zenki
Nismo bushings are quite expensive..
I saw the Peak performance ones... but are those a supplement to the existing bushings? Or they replace them?
180fan
Car: 89 fastback
supplemental.
gumby74
Energy Suspension offers both replacement bushings as well as the urethane spacers. Available thru mynismo.com I think. I have it written down somewhere....
KATastrophic
Car: S13
I believe the only poly one now that works on our cars are the Energy Suspension 300zx ones.
Write ups can be found here,http://240sxforums.com/forums/...74580h ... or...shing
180fan
Car: 89 fastback
Tanabe. The ES ones suck.
KATastrophic
Car: S13
180fan wrote:Tanabe. The ES ones suck.
i thought tanabe only made the collars? do you have a link to their poly?
180fan
Car: 89 fastback
yeah the tanabe's are collars. The ES ones I had were junk and were inserts, not full on bushings either unless they've launched some new product I haven't looked at.
jvladamir
Car: 1995 240sx
I was told by some guys with collars that thats what i wanted to do b/c the poly bushings would rattle my teeth. they suggested stock replacements + collars
180fan
Car: 89 fastback
spacers are fine for the most part unless your bushing itself is pretty much done for in which case then I'd suggest taking a gander at the nismo hard rubber bushings. Fresh bushings without the jarring of poly but without the sloppiness of just plain jane rubber.
