jsomogyi »
https://forums.nicoclub.com/jsomogyi-u74523.html
Sat Jul 12, 2008 6:14 pm
About how many labor hours should it take a mechanic to replace subframe bushings? One of my subframe bushings has been torn, and something is grinding a hole in my gas tank very slowly.
I have an entire kit of polyurathane bushings , so I suppose I should have the mechanic replace all the bushings , instead of just the bad one?
On the bright side, this will present the a good opportunity to have my subframe connectors installed as well
