Also have the oil cooler leak, and already bought the gaskets, just can't find any DIY thread on the fix. is there one on here?
Did you end up doing this yourself? I'm in the same situation and got the same bushings as you show in the image, but it might be too big a job to do by myself? If you did it, how many hours did it take, anything specific to note? If you had someone else do it, how many hours did it take?Rogue Noob wrote: ↑Mon Aug 29, 2016 6:06 pmour 2008 Rogue is really having a lot of issues right now, just changed out the LCA, to discover the subframe bushings are bad too. apparently Nissan is notorious for having low grade bushings. Has anyone changed these themselves? If so, any tips? I did the LCA myself, would like to do this myself too
