Sub
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Devilzblood
Car: Nissan Versa S '08 Sedan - Sapphire Blue
hey guys, i was wondering if someone knows about Sub boxes that go on the side of the trunk
for example the picture below
help is much appreciated, so where can i get it from and about how much would it be, just enlcosure would be good thanks
williamk10
Car: '07 Nissan Versa SL
none mass produced to fit the versa but custom ones have been made before. search this forum for pics
CrankyVersa
Car: 2010 Versa 1.8 hatchback SL
You will have to make a custom one out of fiberglass and MDF to get it to look like that. Also, you will be a need to be able to attach it to the panel, unless you use the panel as a point to build off of.
Return to “Versa Technical Discussions”
