Ok, I have a few questions for you.
1: Are the 2 subs in seperate chambers, or do they share one large enclosure?
2: How are the subs wired? Series or Parallel?
Rex wrote:Now on the speaker side of things, the amp's "output" will be different based on the ohm load it sees and switching rom 1 to 2 subs and back will change the ohm load and thus the output of the amp. If switching to 1 sub increases the ohm load (numerically), then the total bass output would drop by more than in half.
Rex, you need to be slaped on the forhead for saying something like that. I do not mean any offence
If the Ohm load stayed the same with only one of the subs playing, these rules would come into play:
2. If the cone area is halved, the cone excursion is doubled: 6. If the excursion is doubled, the acoustical power is doubled:
Now, if the Power output from the Amp were to drop by ~1/2, because of the doubling of Ohms, this would come into play:
8. If the cone area is halved and the cone excursion remains the same, the acoustical power is decreased by a factor of four
Now, if the Ohm load was decreased by 1/2, the Wattage from the Amp would theoretically increase 100%. Twice the power:
